Finding dervivative of 4x^5(3x^2+3)^3
  • Thread starter Thread starter FaraDazed
FaraDazed
Find the derivative of 4x^5(3x^2+3)^3 by applying the chain rule twice.
I have had a go, but I have not used the chain rule twice so it probably will not be accepted even if it is mathmatically correct. But that is what I wanted to check, if the maths and thinking behind what I done is correct, as when I put it into a derivative calculator the answer is different.
What I did was break it down into two parts, using the chain rule to find the derivative of the second term (the one in paranatheses) and then applied the product rule.
I said...
If g=(3x^2+3)^3 and h=3x^2+3 and that c=h^3
Then, g'=h' \cdot c' = 6x \cdot 3(3x^2+3)^2 = 18x(3x^2+3)^2
Then if m=4x^5 then y'=m' \cdot g + g' \cdot m
y&#039;=20x^4(3x^2+3)^3 + 18x(3x^2+3)^2 \\<br /> y&#039;=20x[x^3(3x^2+3)^3+\frac{9}{10}(3x^2+3)^2 ]
Then I was not sure if doing this makes it look neater or even if its possible, as I am not too sure but if the above is correct then could I do...
20x(3x^2+3)^2[x(3x^2+3)+\frac{9}{10}]
I would appreciate it if someone could check my maths and my method, and also to give advice on how to solve it by using the chain rule twice.
You didn't multiply g' by m in the second term.
Oh yeah, duh!
So then it is...
<br /> y&#039;=20x^4(3x^2+3)^3 + 18x(3x^2+3)^2 4x^5 \\<br /> y&#039;=20x^4(3x^2+3)^3 + 72x^6(3x^2+3)^2 \\<br /> y&#039;=x^4[20(3x^2+3)^3 + 72x^2(3x^2+3)^2 ] \\<br />
I don't see how you can apply the chain rule twice in this problem.
One suggestion I have would be to pull the constants out front in the beginning to make the numbers easier to deal with.
$$y = 4x^5(3x^2+3)^3 = (4\times3^3)[x^5(x^2+1)^3]$$ Then you just differentiate ##x^5(x^2+1)^3## and multiply the result by 108 in the end.
OK, thanks for your help :) . I just double checked the question, it is a question with like 10 parts, (a, b, c, and so on) that came after another similar question with lots of parts. I seemed to have missed where the one question finished and the other started, so for the function talked about here, it does not ask for the chain rule to be applied twice. Sorry for the confusion.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
