Finding Electric Field in Spherical Hole
du_uk
A spherical hole is located inside a uniformly charged sphere of charge density p. The centre of the hole is at a distance a from the centre of the sphere, and the radii of the sphere and the hole are given by R and R' respectively. Determine the electric field strength E inside the hole.
I think I need to use Gauss's law the find the electric field around this red surface:
http://img20.imageshack.us/img20/6870/electroqy.jpg
and since there is symmetry, integrate around 0 to 2(pi) wrt the extra (third dimensional) coordinate.
Then minus the electric field for a sphere outside the charge.
Am I going about this the right way?
Thanks
Hi du_uk, welcome to PF!:smile:
I'm not sure exactly what you mean here, but no, you are not going in the right direction. What exactly is the symmetry you are referring to here?
Instead, take advantage of the superposition principle...what happens if you place an object of charge density -\rho inside a larger object of charge density +\rho?:wink:
More to the point, place a spherical charge density -\rho inside a larger spherical charge density +\rho. What are the forces inside the smaller sphere?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
