Finding Electric Field at a Specific Point and on the Y-Axis
The electric field E at the point (1,2,3) due to the charges Q1 and Q2 is calculated to be 68.92x - 32.319y + 85.936z. To determine where Ex equals zero on the y-axis, the discussion suggests y=32.319 as a potential solution. Further clarification is requested to show the calculations leading to these results for better understanding. The conversation emphasizes the importance of demonstrating the work involved in solving the problem.
intenzxboi
Let a point charge Q1- 25 nc be located at (4,-2,7) and Q2= 60nc be at (-3,4,-2).
a)Find E at (1,2,3) b)at what point on the y-axis is Ex=0
For part a) i found the electric field to be 68.92x-32.319y+85.936z
b)would electric field on Ex be 0 at y=32.319??
Can you show the work you did to get those answers? It is easier to help if you do that.
