Finding Energy Stored in a Capacitor
  • Thread starter Thread starter le@rner
    Capacitor Energy
To find the energy stored in a capacitor in steady state, the correct formula is U = (1/2)CV^2, where C is capacitance and V is voltage. The user initially calculated energy using U = (Q^2)/2C, based on the charge found through loop law, but received incorrect results. The discussion emphasizes the importance of showing work to identify errors in calculations. Clarification on the relationship between charge, voltage, and capacitance is also highlighted. Understanding these principles is essential for accurately determining energy stored in capacitors.
le@rner
How to find the energy stored in the capacitor in steady state in this circuit.
I found out the charge on the capacitor in steady state using loop law and did energy stored = (Q^2)/2C. but its coming out to be incorrect.
What is the expression for energy in terms of C and V? In steady state, voltage and capacitance will be known to you.
But we also know the charge on the capacitor in steady state. Don't we?
Then why is it coming incorrect using this method.
You need to show your work. We can't say much about what you did wrong if we don't know what you did.
Likes davenn
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
