Finding Equilibrium Charge in a Static System
The discussion revolves around finding the charge q1 needed for charge q2 to be in static equilibrium with a given charge Q of -4.6nC. The participant initially struggles with applying Coulomb's Law and setting the forces to zero for equilibrium. They realize that using dimensional analysis could simplify the problem, particularly in understanding the effect of distance on force. After receiving guidance, they acknowledge overthinking the solution. The correct charge q1 is determined to be 18nC for the system to achieve static equilibrium.
LIZard137
In the figure below the charge in the middle is Q = -4.6nC. For what charge q1 will charge q2 be in static equilibrium?
q1-----10cm------Q------10cm------q2
I know that the answer is supposed to be 18nC.
F=Ke lq1llq2l/r2
Since the charges are in static equilibrium, I'd assume that F=0. So...
0=(kel-4.6llq1l/102)+(kelq1lq2l/202)
I've tried several ways of working this problem with Coulomb's Law, but I just can't seem to find the initial step in the right direction.
Hi LIZard137! :smile:
Just use dimensional analysis …
if you double the distance, what happens to the force? :wink:
Wow I completely over thought that... Now I feel retarded lol. Thanks for the help.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
