Finding Force between 2 objects
  • Thread starter Thread starter rollercoaster
    Force
To find the force F acting on two objects in contact on a frictionless surface, start by identifying the forces at play. The force of 3.37 N is the interaction between the two objects, with object 1 experiencing this force as F21 and object 2 experiencing it as F12. Use the equations ΣF1 = m1a = Fx - F21 and ΣF2 = m2a = F12 to set up the problem. Drawing a diagram can help visualize the forces acting on each object. By applying algebra to these equations, the correct force F can be determined.
rollercoaster
Two objects are in contact on a frictionless surface. A horizontal force is applied to one object. Use m1 = 2.86 kg and m2 = 4.92 kg. If a force of 3.37 N acts between the two objects, what is the force F? I don't even know where to start! I've attempted this a numerous amount of times, and I still can't get the correct answer!
F=ma
So are you trying to find the force applied to the first object from whatever is pushing it and 3.37 N is the equal and opposite force applied between? If that is the case, the first thing you should do is just draw a picture with both objects then label all the forces acting on the boxes. Even if you don't know what they are. Disregard n(normal force) and w or mg (force due to gravity). They are not really a factor in this problem. You should for object 1 have a force acting against of 3.37 N(F21, force of object 2 onto object 1), as well as the force applied from whatever is pushing it (Fx). For object 2, you only have the force from object 1 of 3.37 N. Now set up your sum of forces equations.
\SigmaF1=m1a=Fx-F21
\SigmaF2=m2a=F12
Now just do some algebra and you will be able to find the rest.
