Finding force exerted by a rope and ratio of tension:weight
  • Thread starter Thread starter iamjohnny56
    Force Ratio Rope
The problem involves calculating the force exerted by a rope on a 72.8 kg ice skater moving in a circular path with a radius of 0.765 m at a speed of 5.01 m/s. The centripetal force is calculated using the formula Fc = mv^2 / R, resulting in a force of 2.3886108 kN. To find the ratio of this tension to the skater's weight, the weight is calculated as W = mg, which equals 712.64 N. The correct ratio requires both forces to be in the same units, leading to a ratio of approximately 3.348% when expressed correctly. The key takeaway is that unit consistency is crucial in calculating force ratios.
iamjohnny56
A 72.8 kg ice skater is moving at 5.01 m/s when she grabs the loose end of a rope, the opposite end of which is tied to a pole. She then moves in a circle of radius 0.765 m around the pole.
The acceleration of gravity is 9.8 m/s2 .
Find the force exerted by the rope on her arms.
Answer in units of kN = 2.3886108 kN
Find the ratio of this tension to her weight.
Fc = mv^2 / R
W=mg
Fc = mv^2 / R
Fc = (72.8)(5.01)^2 / .765
Fc = 2388.6108 N
Fc = 2.3886108 kN
It's the ratio that's getting me, shouldn't it just be:
2.3886108 kN / (72.8 x 9.8)
=.003348
But the ratio is wrong?
Please help.
The ratio is a comparison of two forces. But they must be in the SAME units!
