How to Find Fourier Coefficients for a Given Function
In summary, the conversation is about finding the relationship between coefficients in the Fourier series for functions g(x) and f(3x). The coefficients for g(x) are denoted by ao_n, while those for f(3x) are denoted by a_n. Through a discussion of a specific example, it is concluded that ao_n equals a_3n for all values of n. This relationship can be easily generalized for other functions.
Kqwert
160
Finding fourrier coefficients by observation
No eq. posted
Hello,
I need help with question #2 c) from the following link (already LateX-formatted so I save some time...):
https://wiki.math.ntnu.no/_media/tma4135/2017h/tma4135_exo1_us29ngb.pdf
I do understand that the a0 for both expressions must be the same, but what about an and bn? I don't understand how you find them, given that we'll have an*cos(nx)/bn*sin(nx) in the first case while we will have an*cos(3nx)/bn*sin(3nx) in the second case.
I don't see them in your attempt at solution
anyway, posts that show no attempt can't be assisted in: PF rules
Okay,
so
[tex]
g(x) = ao_{0} + \sum_{n=1}^{inf} ao_{n}cos(nx)+bo_{n}sin(nx)[/tex]
[tex]
f(3x) = a_{0} + \sum_{n=1}^{inf} a_{n}cos(3nx)+b_{n}sin(3nx)
[/tex]
and [tex] g(x) = f(3x) [/tex]
I understand that
[tex] ao_{0} = a_{0} [/tex], but not sure what to do with the an and bn parts, to make them equal??
Anyways,
think we have to compare the sin and cos terms?
i.e.
[tex]
ao_{3}cos(3x) = a_{1}cos(3x)
[/tex]
so [tex] ao_{3} = a_{1} [/tex] ?
You make life difficult for yourself:
You don't want to make the ##a_n## equal at all !
Try using ##m## as summation variable in the second expression and find a relationship between ##a_n## and ##a_m##
A tip for if you are in a hurry: try a simple example ##f##, for instance ##f(x) = \cos x## :wink:
I edited post #3. Is that correct?
That makes the thread rather difficult to follow, but I think you get the idea, yes.
It's really a very simple exercise if you look 'through' it, isn't it !
Hold it !
In your notation, the alternative ##ao_{n} = a_{3n}## looks more sensible
again: check with ##f=\cos x##
Thanks! not sure how to check that though?
What is the Fourier series for ##\cos x## ?
Idem ##\cos 3x## ?
[tex]
cos(x) = \sum_{n = 1}^{inf} a_{n}cos(nx)
[/tex]
where every [tex]a_{n} [/tex] apart from [tex]a_{1}[/tex] is zero..?
Similarly,
we'll have
[tex]
cos(3x) = a_{3}cos(3x) [/tex]
o:) The above is of course bogus. As you debunked correctly in #11:
If ##f(x) = \cos x \Rightarrow a_1 = 1## and all other ##a_n = 0## then
##\ \ g(x) = f(3x)## has ## a_3 = 1## and all other ##a_n = 0##
which you can easily generalize.
In other words ##\ \ ao_{3n} = a_n \ \ \forall n\ \ ## -- as you concluded in the edited post #3.
What is the purpose of finding Fourier coefficients?
The purpose of finding Fourier coefficients is to represent a periodic function as a combination of simple sinusoidal functions. This allows us to analyze and manipulate the function more easily.
What is the mathematical formula for finding Fourier coefficients?
The mathematical formula for finding Fourier coefficients is given by the integral:
f(x) = a0/2 + ∑(an*cos(nωx) + bn*sin(nωx))
where a0, an, and bn are the coefficients and ω is the angular frequency.
How are Fourier coefficients used in signal processing?
In signal processing, Fourier coefficients are used to decompose a signal into its frequency components. This allows for noise reduction, compression, and other manipulations to be performed on the signal.
What is the relationship between Fourier coefficients and Fourier series?
Fourier coefficients are the numerical values that determine the amplitudes of the sinusoidal functions in a Fourier series. The Fourier series is the sum of these sinusoidal functions, which together approximate a periodic function.
What are the applications of finding Fourier coefficients?
Finding Fourier coefficients has many applications in mathematics, physics, engineering, and other fields. It is used in signal processing, image processing, data compression, and solving differential equations, among others.
