Finding heat transfer coefficient experimentally
The project involves constructing a cubic box to experimentally determine the heat transfer coefficient by analyzing how various objects affect it. The equation Q=h*A*delta-T will be used, with Q representing the heat transfer rate. Thermocouples will measure temperatures on the box's surfaces, treating the space between as a single resistance. The heat transfer rate Q will be calculated by plotting temperature differences over time and taking the derivative. The setup will be placed in an enclosed environmental chamber to ensure controlled conditions.
DinoRF
I'm working on a project where I have to construct a cubic box, then find the heat transfer coefficient through the box. I will be placing various object in the box to run tests on how they change the eat transfer coefficient. If I want to use the equation: Q=h*A*delta-T, how do I find Q, the heat transfer rate?
I'm thinking I will have thermocouples on the outside surface and on object on the inside of the box. I'll treat all the space in between as a single resistance, since I'm not worried about the heat transfer coefficient with respect to convection, radiation, or conduction, but rather the overall coefficient.
If I got the data for the outside temperature and the inside temperature and plotted that vs. time, would the Q just be the difference divided by the time of that difference?
Once I get Q, then solving for h should be simple.
I've also seen heat flux sensors, but those are expensive and I think and hope they are unnecessary.
How are you supplying heat?
I'm putting the entire system in an enclosed environmental chamber.
I'm just going to plot temp/time and take the derivative to find Q. I'm all set. I'm getting ready to build.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
