Finding integral of a helicoid
  • Thread starter Thread starter MasterWu77
    Integral
MasterWu77
Evaluate \int\int \sqrt{1+x^2+y^2} where S is the helicoid: r(u,v) = u cos(v)i + u sin(v)j+vk , with 0\lequ\leq1, 0\leqv\leq\theta.
The S is the area that we are trying to find. the area of the integral i guess.
I know i have to use the \varphi (\theta,\phi) = (acos\theta sin \phi, asin\theta sin \phi, acos\phi)
we did examples like this in class but I'm not sure where to start off. do i need to change the equation of the integral into sin and cos?
you don't HAVE to use phi(theta,phi), you can do this in cartesian coordinates... but i think it would be easier to use a different coordinate system. ( i would suggest trying spherical?)
Yes, I you have to change the object of the integral if you want to use a different coordinate system because "x" and "y" are normally used for cartesian coordinates. theta and r are used for polar coordinates, theta, r and z are used for cylindrial coordinates, phi, rho, and theta are typically used for spherical coordinates.
All of these are just variables tho and can really be anything. They stand for angles and radii of the problem.
Remeber tho, when you change the coordinate system of your integral you have to apply the jacobian. ie, for cylindrical coordinates, the r dr dtheta is appended to the integral, or sphereical is some other trig with phi and theta.
Hope this helps somewhat...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
