Finding length in regular pyramid
The discussion revolves around finding the length of segment TN in a regular pyramid with a square base of 1 cm. Participants highlight the lack of information regarding the pyramid's height or slant height, which is essential for calculating TN. It is clarified that a regular pyramid has an apex directly above the center of the base, and the edges connecting to the apex are each 1 cm long. One contributor suggests that the length of TN is 1/2 √3, which aligns with the properties of the pyramid. The conversation concludes with agreement on the implications of the pyramid's regularity and dimensions.
songoku
Regular pyramid T.ABCD has square base with side 1 cm. N is the mid-point of AB. Find the length of TN
not sure
No information given about the height of the pyramid and the length of the slant-edge, such as TA, so how can we find TN :confused:
Without being given the height of the pyramid (or something equivalent, such as the slant height) then you can't place a value on the length of TN. The only way I can see going about this is to leave the answer in terms of an unknown constant, such as AT, or maybe regular pyramid means something more than just the apex of the pyramid is normal to the centre of the base.
Not sure, but I think regular pyramid means that the apex of the pyramid is normal to the centre of the base and the base has equal side, i.e the base is square.
If I remember correctly, the answer is 1/2 √3. But I can't find it. I have provided the complete question
Ahh ok then, with the answer of \frac{\sqrt{3}}{2} that means the edges connecting to the apex are a length of 1 each, which I guess is what was also implied by the "regular" pyramid.
Ahhh you are correct. Thanks :smile:
