Finding length segment of an ellipse
  • Thread starter Thread starter highwhey
    Ellipse Length
highwhey
i'm having trouble with these solid of revolution problems because a lot of them require you to find "length of the segment" before evaluating the problem. example:
a solid lies between planes perpendicular to x=-5 and x=5. the cross section in the xy plane is the ellipse ((x2)/25)+((y2)/36)=1.
find L=f(x)
does that mean i mean i have to make the given equation a function of x? because when i attempt that, it does not turn out to be correct.
according to the example this is the correct result, L=(12/5)√(25-x2) how can i arrive at that result?
thank you in advance. by the way, i am posting from my ipad so if the format of the question is not correct, i apologize.
find L=f(x)
I have no idea what you are asking. What does "find L = f(x)" mean? Or "find a length segment"? Volume or surface area might make sense.
[Edit] Maybe you are asking for the radius of revolution about the x axis? In which case you would solve for y.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
