Finding Lever Lengths With Overall Mechanical Advantage
The discussion focuses on calculating the lengths of the effort and load arms of a lever given a mechanical advantage (MA) of 10, with a total lever length of 5 meters. The initial approach correctly sets up the relationship between the effort arm and load arm but encounters confusion in isolating the load arm. A participant clarifies that the correct formula for the load arm should involve parentheses to respect the order of operations, leading to a load arm length of 5/11 meters. The conversation emphasizes the importance of proper mathematical operations in solving for the individual arm lengths. Understanding these principles is crucial for accurately determining lever mechanics.
Wolfowitz
If the mechanical advantage of a lever is, let's say, 10; the forces pushing down on the effort arm equate to 100kg and the forces pushing down on the load arm equate to 1000kg and the lever itself is 5 meters, how do we go about finding the individual arm lengths (i.e. the length of the effort/lever arm).
Here's what I'm thinking.
MA = 10
Simultaneously,
MA = Effort Arm / Load Arm
10 = Effort Arm / Load Arm
Load Arm * 10 = Effort Arm
Load Arm + Load Arm * 10 = Effort Arm + Load Arm
2Load Arm * 10 = 5
2Load Arm = 5/10
Load Arm = 0.5
True or false?
MA = 10
Simultaneously,
It is correct up to here, but how did you get the following?
Wolfowitz said:
2Load Arm * 10 = 5
1(load arm)+10 (load arm) = ? (load arm) ?
If you add one apple to 10 apples will you get 2*10 =20 apples?
ehild
Then how would you isolate the load arm?
11 * load arm = effort arm + load arm?
load arm = effort arm + load arm / 11?
No, it is wrong. Division by 11 in your formula refers to the load arm only.
Use parentheses: length of load arm =(length of effort arm+length of load arm)/11, that is, 5/11 m.
Remember the hierarchy of operations: First perform everything in the parentheses. Otherwise perform multiplication/division first then the addition/subtraction.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
