Finding matrix relative to different bases
feinm1
Let B = {b1, b2, b3} be a basis for a vector space V and T : V -> R2 be a linear transformation with the property that
T(x1b1 + x2b2 + x3b3) =
2x1 - 4x2 + 5x3
0x1 - 1x2 + 3x3
Find the matrix for T relative to B and the standard basis for R2.
[T(x)]C = M[x]B
Where M = [[T[b1)]C [T(b2)]C ... [[T(bn)]C
This matrix M is known as the matrix for T relative to the Bases B and C.
[T(x)]C =
2x1 - 4x2 + 5x3
0x1 - 1x2 + 3x3
If [xB] =
|x1|
|x2|
|x3|
Then M =
|2 -4 5|
|0 -1 3|
Is this correct?
feinm1 said:
Is this correct?
Yes, this is just a problem to check if you have understood the concept since they basically gave you the solution. A good way to do these is to check what the standard basis vectors would become, e1 becomes the first column, e2 the second etc. Also always make sure that you are transforming them in the right direction, it is quite easy to mess that up if you don't think while doing this.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
