Finding normal boiling point given pressure and enthelpy.
4 replies · 95K views
webz
Given the following data, determine the heat of vaporization and normal boiling point of ammonia
Temp (K):
200
210
220
230
235
Pressure (respectively)(torr):
65.3
134.3
255.7
456.0
597.0
ln(p2/p1)=-deltaH/R(1/t2-1/t1)
I have calculated using the first two sets of data that deltaH should be 25.179kJ/mol. The books answer within 1kJ/mol, so I'm assuming that they just used different data to come up with it. Anyways, I'm having a problem on the second part of the question where it asks to come up with a normal boiling point. The normal boiling point is when the vapor pressure equals the external pressure, right? But I have no variable in this equation that will give me the normal boiling point. Do I use this equation for both portions to the question? I'm confused. I should be able to solve the problem, just need a little boost please.
You have a function that correlates vapor pressure with temperature, yes?
What is the pressure at the normal boiling point?
So if the normal boiling point is where the vapor pressure equals the external pressure, I can just set p2/p1 to 1.
So I have ln1=-25.179/8.314(1/210-1/T) then T equals the normal boiling point? Eh, I'm confused.
No.
What is the difference between the definitions of "boiling point" and "normal boiling point"?
PhaseShifter said:
No.
Oh I get it now! The normal point is at STP. Ugh why didn't I see that before
ln(760/65.3)=-25719/8.314(1/x-1/200)=~239K
Thank you!
