What Is the Peak Value of the E-Field If the Magnetic Field Is 2 x 10^-7 T?
The peak value of the electric field (E) in an electromagnetic wave can be calculated using the formula E = cB, where c is the speed of light. Given a magnetic field (B) of 2 x 10^-7 T, the calculation yields E = 60 N/C. The initial query confirms the correctness of this calculation. The response affirms that the calculation is accurate. The discussion effectively clarifies the relationship between the electric and magnetic fields in electromagnetic waves.
jena
Hi,
My Question:
If the peak value of the magnetic field of an EM wave is 2 x 10^-7 T. Calculate the peak value of the E-field.
Work:
C=E/B so,
3*10^8 m/s=(E)/(2*10^-7 T)
(3*10^8 m/s)(2*10^-7 T)=E
E= 60 N/C
Is this right ?
Thank You
Hi,
I'm sorry but I just wanted to know if I did this problem correctly
Thank You
Yea that's correct.
E = CB
