Finding removable and jump discontinuities
  • Thread starter Thread starter DanielJackins
    Jump
DanielJackins
f(x) = -x + b, if x < 2
= 5, if x = 2
= -20/(x-b) + 1, if x > 2
For what value(s) of b does f have a removable discontinuity at 2?
For what value(s) of b does f have a (finite) jump discontinuity at 2? Write your answer in interval notation.
I'm completely stumped on the removable discontinuity, because I thought you had to be able to cancel out the bottom?
And I'm not sure how to find a jump discontinuity.
A removable discontinuity is a value of b where the limit as x->2 from below and the limit as x->2 from above are equal. Your first job is to find those two limits in terms of b. Then equate them. Can you do that?
Are the limits not -inf and inf?
No. The limits as x->2! The limit from above is (x>2) is -20/(2-b)+1, isn't it? What's the limit from below?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
