Acuben
- 61
First of all, thank you taking a look at this. I hope to return to community in the future as I got help today.
I'm assuming this belongs to introductory physics, so I'll post here, feel free to move if I posted in wrong section.
A carbon wire and a Nichrome wire are connected in series, so that the same current exists in both wires. If the combination has a resistance of 10.0k\Omega at 0celcius, what is the resistance of each wire at 0Celcius? so that the resistance of the combination does not change with temperature? The total or equivalent resistance of resistors in series is the sum of their individual resistances
\rho is rho which stands for resistivity
\alpha is alph which stands for Temperature coefficient
\rho(carbon)=3.5x10^-5
\alpha(carbon)=-0.5x10^-3
\rho(nichrome)=1.5x10^-6
\alpha(nichrome)=0.4x10^-3
I honestly have no idea what equations to use here, but i'll put what can possibly be used
Resistivity and Resistance changes by temperature
\rho(0) stands for resistivity at 20celcius
R(0) stands for Resistance at 20celcius
\DeltaT is T(final)-T(0) and T(0) is 20celcius
\rho=\rho(0)[1+a*\DeltaT]
R=R(0)[1+a*\DeltaT]
I=electrical current in units Ampere
V=Voltage in coulomb
I=\DeltaV / R
and general R=\rho * l / A
where...
l= length
A= area
this equation may be manipulated like...
R(carbon)=R(0carbon)[1+a(carbon)*\DeltaT]
R(nichrome)=R(0nichrome)[1+a(nichrome)*\DeltaT]
add these two equation and...
R(total)=R(0carbon)[1+a(carbon)*\DeltaT] + R(0nichrome)[1+a(nichrome)*\DeltaT]
and R(total)=10.0\Omega
I don't think none of the work I have so far is useful... if necessary, i'll post more info
I'm saying I don't think they'll help because I don't think the work I have is toward the right direction xD
but so far I added R(carbon)=R(0carbon)[1+a(carbon)*\DeltaT]
and since temperature does not change, R(nichrome)=R(0nichrome) and R(carbon)=R(0carbon)
same goes for \rho
It's given that I (current) is the same and I'm guessing that voltage is the same as well opening room for...
R(total) = V/I
although this seems to be irrelevant...
and to poke the problem from different angle...
can I safely assume that \alpha(total)=C*\alpha(carbon) + N * \alpha(nichrome)
C= percentage of carbon
N= percentage of Nichrome
assuming percentage is percentage of free electrons? (or should I try mass?)
anyways, hardest part for this problem is setting up the problem. Even conceptual answer would be helpful. I need know what "directions" I should take =p right now I'm just poking the problem from every side aimlessly.
thank you.
edit: Answer is 5.56k\Omega, 4.44k\Omega (i don't know which one's which, but I don think that'll be problem once I figure out how to solve this problem).
edit2: I added
R(carbon)=R(0carbon) * [1+\alpha(carbon)\DeltaT]
R(nichrome)=R(0nichrome) * [1+\alpha(nichrome)\DeltaT]
and canceling out lots of "R" (considering R(total)=R(0total)
R(0total) is R, resistance, at 20celcius
R(total) is resistance at 0 celcius
I know that R(carbon)+R(nichrome)=R(total)=10.0 k Ohms
but i forgot to use this as well since total resistance is always 10.0k Ohms regardless of temperature
R(0carbon)+R(0nichrome)=R(0total)=10.0 k Ohms
anyways after adding those two equations (right under edit:2) I got up to R(0carbon)=4.44k Ohms.
Problem is, the problem asks for R(carbon) not R(0carbon)
so I use R(carbon)=R(0carbon) * [1+\alpha(carbon)\DeltaT]
and I get R(carbon)=4.40k Ohms... my R(0carbon) is rather closer to the answer ><
R=R(0)[1+a*\DeltaT]
I=\DeltaV / R
where...
l= length
A= area
same goes for \rho
R(total) = V/I
thank you.
edit2: I added
