Finding Resonating Frequencies in Pipes
The discussion centers on understanding the resonance frequencies in open and closed pipes, particularly focusing on a pipe of 33 cm length. The user is struggling with calculations for the wavelength and frequencies of harmonics, specifically the second harmonic and the next higher frequency. They correctly calculate the fundamental frequency as 1039 Hz but face confusion regarding the next harmonic, with discrepancies between their calculations and their teacher's explanations. Additionally, they seek clarity on the length of a closed pipe required for the original tuning fork to resonate at its fundamental frequency. The thread highlights the importance of understanding the relationship between harmonics, wavelength, and pipe length in acoustics.
metsjetsfan
So my teacher is horrible, and I pretty much have to teach myself everything. With this question, I am getting different answers than my teacher, and my teacher has been unable to explain to me satisfactorily why and how she got her answers.
So please help me out, and even give some kind of concept explanation if you can.
Thanks
A sound wave resonates inside an open pipe filled with air at room temperature at 2nd harmonic and 1st overtone. The length of the pipe is 33 cm.
a-determine the wavelength of the resonating sound wave
b-determine the frequency of the tuning fork
c-determine the next higher frequency that will resonate in a pipe of this length
d-if the open pipe is replaced with a pipe which is closed at one end, what would have to be the length of the closed pipe for the original tuning fork to resonate at its fundamental frequency?
I actually found this equation on my own and my teacher didn't use it, but here it is:
f=nv/2L
(a)-pretty simple i thought. wavelength=2L/n so wavelength= 33 cm
(b)-this was ok, though not completely sure.
f=nv/2L=2*343/(2*0.33)=1039 hz
(c)-this is where the problems arrive:
since i believe it's asking for the third harmonic (the next higher frequency that will resonate) i thought i should just do:
f=nv/2L so f= 3*343/ (2*0.33) = 1559 hz
but my teacher said that L= 2*wavelength, and wavelength = L/2 = 0.33/2= .166
and f = 343/.166 = 2078 hz
but i think that is the fourth harmonic, which is not what we're looking for. This is where my problem comes in terms of concept.
(d) ok this was the hardest part. the diagram shows what looks like a fourth of a wavelength in the pipe with a node at the closed end. so i thought that I should set the fundamental frequency of the first tuning fork, which i found to be 520, equal to v/4L.
I then got 4L = 0.66, L= 16.5 cm
But my teacher just did L=wavelength / 4 = .33/4 = 8.25 cm
PLEASE HELP ME. My teacher is killing me, and I could really use guidance on this stuff.
Thanks to anyone who responds.
For an open ended column then you have the wavelength is the length of the column.
http://www.glenbrook.k12.il.us/GBSSCI/PHYS/Class/sound/u11l5c.html
You get a frequency of 1039hz looks like to me.
The third harmonic for an open ended pipe is one more 1/2 wavelength. (3 times the fundamental).
For the closed end pipe:
http://www.glenbrook.k12.il.us/GBSSCI/PHYS/Class/sound/u11l5d.html
Recall that the wavelength of the tuning fork before was 33cm, so 1/4 of that would be 33/4 wouldn't it?
so is the answer to part c 1559 then?
and for part d, my problem is that the fundamental frequency for the original tuning fork would be 520 hz because that is half of the 1039 hz from part b.
but then that means the wavelength= 340 m/s / 520 hz = .65 m. And then 1/4 of .65= .1625.
I understand the shortcut for why it is 33/4 but why does it not work the long way?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
