Finding Solutions to Complex Linear Systems
3.14159265358979
Find the solution in C to the following linear system of equations.
(a) (1-i)z + 4w = 2 + 8i
(b) 3z + (1+i)w = 1 + 5i
I tried expanding but that didn't get me anywhere. Then i put it in a matrix, but i didn't know how to go from there. Any suggestions? Thanks.
1.Multiply your first equation with 3/2*(1+i)
You should then have 3z in both equations.
2. Then subtract the first from the second and solve for w.
3) Don't bother to expand brackets until you've solved for w and z
Don't be intimidated by the complex numbers. You would solve this problem exactly as you would if there were only real numbers involved.
For instance, in the first equation, the coefficient on z is simply the (single!) number (1 - i). So, if when solving systems of equations, you like to divide through by the leading coefficient, then you would do so, by dividing through by (1 - i).
thanks guys...i think i got it...
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
