Finding Speed of Efflux for Two Liquids of Different Densities
  • Thread starter Thread starter zorro
    Liquids Speed
The discussion focuses on calculating the speed of efflux for two immiscible liquids of different densities in a container. The pressure difference at the hole is derived from the heights and densities of the liquids, leading to an initial velocity formula. A key point raised is the need to consider how the density of the liquid flowing out changes over time, as initially, it is 2d, but later it becomes d. The participants clarify the pressure difference equation and the implications of changing liquid levels on efflux velocity. Ultimately, the discussion emphasizes the importance of accounting for varying densities in dynamic fluid scenarios.
zorro
The container of uniform cross section area A holds two immiscible non-viscous incompressible liquids of densities d and 2d each of height H/2. A tiny hole of area S<<A is punched on the vertical side of the container at height h(<H/2)
Find the speed of efflux.
I know how to find it when there is only one liquid present.
What is the approach in this case?
P - Po = g[H/2*d + (H/2-h)*2d ]
The density of the liquid flowing out is 2d. Hence the velocity of the liquid is
v = sqrt[2(P - Po)/2d]
Substitute the values and find v.
P - Po = g(H/2*d + H/4*2d) = gHd
how did you get H/4*2d? the height 'h' is a variable.
After some time density of liquid flowing out will be d. But we are not taking it into account. Why is it so?
Abdul Quadeer;2906559[B said:
]how did you get H/4*2d?[/B] the height 'h' is a variable.
It should be (H/2 - h)*2d
From the expression we get only the initial velocity. As the level of the liquid decreases, the velocity will also change. When the liquid with density d flows out, again velocity will change.
Thanks alot, Sir.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
