Finding temperature after something falls
  • Thread starter Thread starter crazyog
    Temperature
The discussion revolves around calculating the final temperature of 1.0 kg of lead after it falls 200 m, starting at 300 K. The specific heat of lead is given as 128 J/kg°C, and the initial calculations led to confusion regarding the correct answer. The correct approach involves using the equation mc(Tf - Ti) = mgy, where the masses cancel out, simplifying the equation. The final temperature is determined to be approximately 315 K, confirming the teacher's answer. The thread also notes a technical issue with marking the discussion as solved.
crazyog
What is the temperature in K of 1.0 kg of lead initially at 300 K after it falls 200 m? The specific heat of lead is 128 J/kg C.
a) 307 b) 311 c) 315 d)275 e) 279
the answer my teacher said was c but i keep getting a.
I thought I would use mc (Tf-Ti) = mgy
The masses cross out. so
(300)(delta T) = (9.8)(200)
I get delta T = 6.53
300 +6.53 = 306.53
Hi crazyog! :smile:
erm … why are you using 300 for c? :wink:
(1kg)(128) (Tf - 300) = (1 kg) (9.8) (200 m)
128Tf - 38400 = 1960
Tf = 315.31
thank you! :)ehh, how do I mark this solved?
Hi crazyog! :smile:
I think the "SOLVED" facility got lost in the recent upgrade.
Maybe it'll come back! :rolleyes:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
