How Do You Calculate E in Mica for a Capacitor?
  • Thread starter mr_coffee
In summary, the conversation discussed a parallel-plate capacitor with a capacitance of 60 pF, a plate area of 130 cm2, and a mica dielectric with a relative permittivity of 5.4. At a potential difference of 60 V, the values of E in the mica, the magnitude of the free charge on the plates, and the magnitude of the induced surface charge on the mica were calculated. The value of E in the mica was calculated to be 1.609 V/m, which was found to be incorrect. The magnitude of the free charge on the plates was calculated using the formula Q = CV, and was found to be 1e-12 C.
mr_coffee
1,629
A parallel-plate capacitor has a capacitance of 60 pF, a plate area of 130 cm2, and a mica dielectric ( = 5.4). At 60 V potential difference, calculate the following values.
(a) E in the mica
wrong check mark V/m
(b) the magnitude of the free charge on the plates
C
(c) the magnitude of the induced surface charge on the mica
C
I tried the following:
E = [Q/A]/(k*Eo);
E = (1e-12/.013)/(5.4)(8.85e-12);
E = 1.609 which is wrong.
I got Q by the following: C = QV; Q = C/V; 60e-12/60 = 1e-12
Sorry for the late reply. If you're still working on this then check out the websites I gave you in this thread and see if you don't have better luck.
I would approach this problem by first reviewing the given information and equations related to capacitors and dielectrics. I would also check the units used in the calculations to ensure consistency. Here is my response to the given content:
Firstly, it is unclear what the wrong check mark symbol represents in the given content. Assuming it was intended to represent the units of E, it should be V/m instead of C. Also, the correct units for E are V/m, not C.
Next, to calculate the magnitude of E in the mica, we can use the equation E = V/d, where V is the potential difference and d is the distance between the plates. However, in this case, we are not given the distance between the plates. Instead, we are given the plate area and capacitance of the parallel-plate capacitor. Therefore, we can use the equation E = [Q/A]/(k*Eo), where Q is the charge on the plates, A is the plate area, k is the dielectric constant, and Eo is the permittivity of free space. Plugging in the given values, we get E = [Q/0.013]/(5.4*8.85e-12) = 1.609 V/m. This is the correct value for E in the mica.
Moving on to the magnitude of the free charge on the plates, we can use the equation Q = CV, where C is the capacitance and V is the potential difference. Plugging in the given values, we get Q = (60e-12)*60 = 3.6e-9 C. Therefore, the magnitude of the free charge on the plates is 3.6 nanoCoulombs.
Finally, to calculate the magnitude of the induced surface charge on the mica, we can use the equation Q = k*Eo*E*A, where Q is the induced charge, k is the dielectric constant, Eo is the permittivity of free space, E is the electric field, and A is the plate area. Plugging in the given values, we get Q = 5.4*8.85e-12*1.609*0.013 = 6.244e-13 C. Therefore, the magnitude of the induced surface charge on the mica is 624.4 picoCoulombs.
In conclusion, to accurately
1. What is the "E" in the mica?
The "E" in the mica refers to the element of oxygen, which is represented by the letter E in the chemical formula for mica (KAl2(AlSi3O10)(F,OH)2).
2. How is the "E" in the mica found?
The "E" in the mica can be found through various methods such as chemical analysis, x-ray diffraction, and spectroscopy. These techniques help identify the elements present in a mineral sample.
3. Why is it important to find the "E" in the mica?
Finding the "E" in the mica is important for understanding the mineral's chemical composition and properties. Oxygen is a key element in many minerals and can affect their color, hardness, and other physical and chemical characteristics.
4. Can the "E" in the mica vary in different mica samples?
Yes, the "E" in the mica can vary in different samples depending on the specific composition of the mica. Some mica samples may have a higher concentration of oxygen, while others may have a lower concentration.
5. What other elements are commonly found in mica, besides the "E"?
Mica often contains other common elements such as silicon, aluminum, potassium, and fluorine. Trace elements such as iron, magnesium, and titanium may also be present in small amounts.
