Finding the formula for the partial sum Sn
chris4642
Consider the series Ʃ 1/[k(k+2)]; n=1 to infinity
Find the formula for the partial sum Sn
2. The attempt at a solution
I have calculated the first 5 terms of the sequence as follows, but I can't see any pattern. Am I doing this right?
S1=1/3
S2=1/3+1/8=11/24
S3=1/3+1/8+1/15=21/40
S4=1/3+1/8+1/15+1/24=17/30
S5=1/3+1/8+1/15+1/24+1/35=25/42
Sn=? I can't find any ratio or exponential relation between the terms. I need to find a general formula for Sn
on Phys.org
Hint: [itex]\frac{1}{k(k+2)}=\frac{1}{k}-\frac{1}{k+2}[/itex]. Your series is telescoping.
Telescoping series
Ok I have read a bit on telescoping series. One thing I do not understand is this:
Why does it go from 1/[k(k+2)] to 1/k - 1/k+2, why are they subtracted instead of added?
What happens if you simplify ##\frac 1 k - \frac 1 {k+2}##? Does it equal ##\frac 1 {k(k+2)}## or not? That will answer your question.
It is [itex]\frac{1}{k(k+2)}=0.5\left(\frac{1}{k}-\frac{1}{k+2}\right)[/itex]
ehild
Have you learned about partial fractions?
More to the point, don't you know how to add and subtract fractions?
To add or subtract 1/k and 1/(k+2) (the parentheses in that second fraction are important!) you need to get the same denominator which is, of course, k(k+2).
1/k+ 1/(k+2)= (k+2)/k(k+2)+ k/k(k+2)= (2k+2)/k(k+2)
1/k- 1/(k+2)= (k+2)/k(k+2)- k/k(k+2)= 2/k(k+2)
Which is the one you want?
