Finding the Gamma Distribution of X1+...+Xn
  • Thread starter Thread starter glacier302
    Distribution Gamma
glacier302
Let X1,...,Xn be independent, identically distributed random variables with exponential distribution of parameter λ. Find the density function of S = X1+...+Xn. (This distribution is called the gamma distribution of parameters n and λ). Hint: Proceed by induction.
The probability density function of each of the Xi is f(x) = λe^(-λx).
The probability density function of the sum of two independent random variables is the convolution of their density functions. So if the density function of X is f(x) and the density function of Y is g(x), then the density function of X+Y is ∫f(T)g(x-T)dT (integral from -∞ to ∞).
At first I tried computing the characteristic function of X1+...+Xn, which is equal to the characteristic function of X1 raised to the nth power since the Xi are independent and identically distributed. But this didn't look like the characteristic function of any probability distribution that I know, so that was a dead end.
We're told to proceed by induction, but I'm not sure how to do that with density functions.
Any help would be much appreciated! : )
I would begin by actually calculating that convolution integral. So letting f(x) represent your exponential distribution λe-λx you want to calculate
\int_{-\infty}^\infty \int_{-\infty}^\infty f(t)f(x-t)\, dt
But you need to take care about the limits. Remember the exponential distribution is zero whenever its argument is negative. So your first problem is to put in the exponential functions with the correct limits for the non-zero domain. Then just do the integral and look at its form. Then you will be ready to try the induction step.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
