Finding the magnitude of a vector B given vector C
  • Thread starter Thread starter Cadawallader
    Magnitude Vector
5 replies · 2K views
Cadawallader
If vector B is added to vector C = 3.7i + 2.4j, the result is a vector in the positive direction of the y axis, with a magnitude equal to that of vector C. What is the magnitude of vector B?
sqroot(a^2x+a^2y) = a
My line of reasoning: since the magnitude of vector B is equal to the magnitude of vector C, then finding the magnitude of vector C using the given components would yield the magnitude of vector B.
How I went about solving the problem:
I used 3.7i as the x component of C and 2.4j as the Y component, then plugged each component into the following formula: c = sqroot(c2x+c2y). I received an answer of 4.4 but it has been marked as incorrect.
Please let me know why my reasoning is incorrect (I don't need the answer).
BvU said:
Hello Cada, welcome to PF :smile: !
Did you make a drawing of the situation ?
Hi,
Thanks for replying. No, I had not created an illustration of the situation at the time since I did not believe it would be necessary for this question.
I created one just now but I still do not see how it will help yield the magnitude of vector C.
Here is the drawing: http://i60.tinypic.com/2zrf6og.jpg
Hello,
Apologies.. I am reading the question incorrectly therefore assuming that the magnitude of vector B is equal to that of vector C when this is not the case.
I will give this another go - thank you for suggesting to draw this and helping.
Dear Cad,
In the picture it is hard to imagine you made the magnitude of ##\vec a## equal to the magnitude of ##\vec c##. -- Ah, you've got it! See that making a picture helps out ?
