Exploring the Conservation of Momentum and Energy in a Tarzan Swing Collision
  • Thread starter bieon
  • Tags
    Mass
In summary, we have a problem involving a pendulum with two masses, where the initial angles and masses are given. The length of the vine remains constant in both the initial and final positions. Conservation of energy and momentum can be applied to the swing down from the starting point to the bottom, the collision as Tarzan grabs Jane (which is a perfect inelastic collision), and the swing up to the final height. The velocity can be calculated using the formula V2=[m1/(m1+m2)]v1.
bieon
32
Jane thinks that Tarzan has been gaining too much mass. However, he doesn’t want to tell her what he weighs. One day Tarzan is swinging in the forest. He starts from rest from one side at an angle of 53° from the vertical. He swings down and grabs Jane at the bottom of the swing. They swing together on the other side up to a maximum angle of 37 °. Jane knows that her mass is 50 kg. Calculate Tarzan’s mass. (Ans.120.8kg)
Refer Below.
My Attempt So Far:
1) Drawing a diagram based on the question.
Diagram 1: Pendulum Diagram Based On Question
2) List down pieces of information found in the question.
θ1=53°
θ2=37°
m1=m1
m2=m1+50kg
v
i=0
3) Since 53°+37°=90°, I redraw another diagram making it into a right angle triangle in order to find the length of the vine.
Since the length of the vine is the same in the initial location and final location, I assumed that the adjacent and opposite sides are equal.
Diagram 2: Right-Angled Triangle Derived From Question
4) I then tried to find the length of x by applying the Cosine Rule.
c2=a2+b2-2ab(cos C)
Equation 1: Cosine Rule
x2=a2+x2-2ax(cos 45)
Substitute the unknowns with the numbers or unknowns that are shown in the diagram drawn.
-a2=-2ax(cos 45)
Cancel like terms and try to put everything in term of a
a=√2 x
Let this equation be the first equation.
5) After getting the first equation, I tried finding the length of the vine by using sin θ = Opposite/Hypotenuse
sin 45 = x/a
sin 45 = x/√2 x
sin 45 = √2/2
√2=x
2=a
I was stuck from this point on... Any help is appreciated...
Likes Delta2
Why not let the length of the vine be ##l## and see what you get. Perhaps ##l## will cancel out.
Hint: think about conservation of momentum and energy. Where and when do these apply in this problem?
In addition to following @PeroK's advice about the length of the vine, compare the situation immediately before and immediately after Tarzan grabs Jane. What's different? What remains the same?
So I am assuming that the initial position has mgh,
So, at the initial position, there is mgh, but no 1/2mv2? Since it started at rest? then at the middle point when he grabbed Jane, the mgh is 0? After that I am not sure
The mass and velocity? I am assuming that as the mass increase the velocity decreases?
Yes, at the initial and final positions, there is potential energy but no kinetic. And it's OK to measure PE from the lowest point.
bieon said:
So I am assuming that the initial position has mgh,So, at the initial position, there is mgh, but no 1/2mv2? Since it started at rest? then at the middle point when he grabbed Jane, the mgh is 0? After that I am not sure
In physics terms what can you say about the process of Tarzan picking up Jane? Is energy conserved? Is momentum conserved?
So, um Energy cannot be destroyed but it can be transfer? I assume the momentum is conserved as the momentum before and the momentum after is equal when there are no external forces
By that, since the energy is conserved, I can assume that the PE of initial and final to be equal right?
Consider this in three parts: The swing down from the starting point to the bottom; The "collision" as Tarzan grabs Jane (what kind of collision is this?); The swing up to the final height.
In each of these parts, some quantities are conserved while others are not.
Likes PeroK
When Tarzan grab Jane, it stick together, so it would be... perfect inelastic collision?
Likes PeroK
Exactly! Make use of that insight.
so... V2=[m1/(m1+m2)]v1
(Sorry, I don't know how to use fraction here...)
What about the velocity though?
Can you relate ##v_1## and ##v_2## to the initial and final positions?
Likes Doc Al
##v_1## the initial velocity is at zero, since it's stated that Tarzan was at rest...
##v_2## the final velocity is it zero too? Since he stopped?
(I am really sorry for taking so much of both of your time...)
##v_1## and ##v_2## are the velocities immediately before and after the inelastic collision.
Hmm... This is slightly confusing...
So there will be a ##v_f## for final velocity of both right?
In your momentum equation, that "final" velocity is ##v_2##.
##v_2##=[##m_1##/(##m_1##+##m_2##)]##v_1##
This equation?
How do I use this to obtain the final velocity when I don't know the ##v_1##?
This equation?
As @PeroK suggested, express those velocities in terms of the initial and final positions. (What's conserved during those swings?)
The momentum is conserved?
Position as in displacement?
To give you a bit more help, let me show you how I would set up this problem. There are three phases.
The first phase is Tarzan swinging. Energy is conserved. Let's say the energy is ##E_1##. We start with GPE and end with KE.
The second phase he collides with Jane and energy is lost. After the collision the energy is ##E_2##.
We can relate ##E_1## and ##E_2## by conservation of momentum.
The third phase is both swinging up. Again energy is conserved and KE becomes GPE.
Note: you have to be careful if you like using "initial" and "final" terminology. These apply to each phase of the motion. Especially for more complicated problems I prefer using ##v_0, v_1, v_2, v_3## etc.
In this problem ##v_0 = 0## and ##v_3 = 0##, so we don't even need those.
But we do need ##v_1## and ##v_2##, as the velocities just before and after the collision.
So.
##E_1##=##m##g##h##+½mv12
##E_2## = ½(m+50) v22
then
##E_1## = ##E_2##
bieon said:
So.
then
##E_1## = ##E_2##
No.
##E_1 = Mgh_1 = \frac 1 2 Mv_1^2##
##E_1 \ne E_2##
##E_2 = (M + m)gh_2 = \frac 1 2 (M+m)v_2^2##
Where ##M## and ##m## are the masses of Tarzan and Jane.
I suspect this problem is a lot harder than the ones you are used to. Solving this problem involves a strategy, not just plugging numbers into an equation!
PeroK said:
No.
##E_1 \ne E_2##
I am sorry, I am really not used to these questions... I believe I need more practices!
PeroK said:
No.
##E_1 \ne E_2##
So...
(##M##+##m##)##v_2##=##Mv_1##
Without Jane,
##Mg##(1-##cos##53)=½ ##Mv_1##2
With Jane,
##(M+m)g##(1-##cos##37)=½ ##(M+m)v_2##2
bieon said:
So...
##(M+m)v_2=Mv_1##
Without Jane,
With Jane,
That's the idea.
Although the length of the vine should be in there somewhere.
PeroK said:
That's the idea.
Ah dang... :/
  • #31
bieon said:
Ah dang... :/
Try leaving it as ##h_1, h_2## for now. That's simpler. We can sort out these in terms of angles later.
  • #32
Like this?
Without Jane,
##Mg##(##h_1##)=½ ##Mv_1##2
With Jane,
##(M+m)g##(##h_2##)=½ ##(M+m)v_2##2
  • #33
bieon said:
Like this?
Without Jane,
With Jane,
Yes. Now you need the equation for ##v_1## and ##v_2## you got from conservation of monentum.
  • #34
PS note that the masses cancel in those equations, so that simplifies things a bit.
  • #35
PeroK said:
PS note that the masses cancel in those equations, so that simllifies things a bit.
Ok, so I put them in terms of velocity now right?
M##g##(##h_1##)=½ M##v_1##2
2##g####h_1##= ##v_1##2
With Jane,
(M+m)##g##(##h_2##)=½ (M+m)##v_2##2
2##g####h_2##= ##v_2##2
