What Is the Maximum Elongation of the Spring Between Two Moving Discs?
The discussion revolves around calculating the maximum elongation of a spring connecting two identical discs on a smooth horizontal plane, with one disc set in motion. Participants emphasize the importance of using the center of mass frame to simplify the problem and apply conservation of energy and momentum principles. There is a consensus that the initial kinetic energy of the moving disc converts into potential energy stored in the spring at maximum elongation. Several users express confusion over the dimensions of the provided answer and suggest it may contain a typo. Ultimately, the correct expression for maximum elongation is derived as ##\frac{mv_0^2}{kl_0}##, assuming corrections to the initial answer.
  • #51
Okay...Things look better if we work from the CM frame.Lets leave this frame for a while .
I had worked from the Lab frame in#41 .What modifications do we have to make in #41 when we are working the problem in Lab frame ?
Can't we capture the essence of the problem in the ground frame? I apolozise for my limitations in understanding the problem at hand.
  • #52
In that case angular momentum will not be conserved, as there is a torque acting on the masses.
  • #53
Tanya Sharma said:
I understand that the system rotates,but how does disks move perpendicularly to the spring connecting them.The disk initially at rest can move in the direction of applied force which will be along the spring.Yes,the disks will move such that both the linear momentum and angular momentum are conserved.
I am still unable to understand ,where I am getting it wrong with linear momentum and energy conservation .
The conservation of linear momentum and angular momentum is OK, but it is not, that the disks can only move along the spring. Initially, one disk is given a kick initially somehow, that was an external force. Imagine that the spring is rigid so it is straight during the motion, but under the initial impulsive force it can bend a bit, so all points of the spring get some velocity (fig 1a). After the kick, the CM will move horizontally with Vo/2. Figure b shows the situation just after the kick in the CM frame of reference. The disks move with Vo/2 and -Vo/2 horizontal velocities, so they stretch the spring. Therefore they experience the spring force (the green arrows), accelerated inward by it, changing the direction of the velocity. Their outward radial components decrease. At the end, at maximum elongation, the velocities become normal to the spring, and the whole system rotates about the CM as a rigid body at that instant (fig.c)
ehild
Likes 1 person
  • #54
No torque acts on the system comprising spring and masses .Angular momentum is definitely conserved.
  • #55
I'm not sure to what extent you want the lab frame to be used. What I mean by this is that even in the lab frame, we can describe the motion at the instant of maximal elongation as a translation of the CM (the CM starts at the origin with velocity ##\frac{v_0}{2}## and since ##\frac{\mathrm{d} P_{\text{net}}}{\mathrm{d} t} = 0##, the CM moves in a straight line with constant velocity ##\frac{v_0}{2}## starting from the origin) plus a rotation of the disks about the CM. This allows us to write the kinetic energy at that instant, in the lab frame, as ##T_f = \frac{1}{2}(2m)(\frac{v_0}{2})^{2} + \frac{1}{2}k(2x)^{2} + \frac{1}{2}I_{cm}[(\omega^2_{1})_{f} + (\omega^2_{2})_f]## where ##(\omega_{1})_f## and ##(\omega_{2})_f## are the angular velocities of the disks about the CM at the instant of maximal elongation. We can find ##(\omega_{1})_f## and ##(\omega_{2})_f## using conservation of angular momentum in the exact same way as before and we will get the same answer as before after using conservation of energy (the initial kinetic energy is just ##T_i = \frac{1}{2}mv_0^{2}##).
EDIT: ehild that is a perfect diagram. Why are you so awesome :)?
Likes 1 person
  • #56
I do not have enough brains to understand complicated problems without imagining a picture :-p
ehild
  • #57
Yes, silly answer on my part. No external forces. Don't know what I was thinking.
  • #58
ehild
Excellent explanation :)
Does that mean ,once the spring attains maximum elongation,the masses rotate about the CM ,while spring maintaining this maximum elongation (i.e there is no further change in spring length) ?
EDIT:I agree WNB,ehild is truly awesome.
  • #59
That is what I was thinking as well. Torque on a system can exist even if external forces do not - is that right?
  • #60
No it will definitely change. The spring force will pull the disks back.
  • #61
I accidentally deleted my comment when trying to edit it :[ but if you want you can go ahead and give your reasoning.
  • #62
I'll just re-post what WBN said in short ; torque is not zero since at any instant of time since the radius vector w.r.t lab frame of any particle is NOT parallel to the spring force acting on the mass. Hence angular momentum is not conserved.
  • #63
WNB,I beg to differ with your view .With respect to a fixed origin,the angular momentum of the CM remains constant .Again,Angular momentum of the masses w.r.t CM remains constant.The total angular momentum of the system comprising spring and masses remains constant w.r.t fixed origin .
Again, where is the force applying net torque on the system ?
  • #64
Never mind, I agree with Tanya. One can show that if the net force on a system of particles is zero then the net torque on the system is the same about all origins (proof on request). The net force on the spring+disks system must vanish in any inertial frame hence the net torque about the lab fame origin should be the same as the net torque about the CM i.e. zero. If there is a flaw in this argument then maybe ehild or someone else can point it out. What I was thinking of before was the torque about the lab frame origin on a single disk not vanishing, as opposed to the net torque about the lab frame origin on the system.
  • #65
In the C.M frame, at the instant of maximum elongation, we will have both masses moving only tangentially with a velocity, and a radial force acting on them. How do we prove that this does not result in a circular motion with a constant radius? Will we have to show that mv^2/(l/2 + x/2) \neq k(l+x) meaning the spring force does not provide the required centripetal force?
  • #66
There are far more twists and turns in the movie than what I anticipated .:smile:
WannabeNewton,I really appreciate your patience and knowledge .
I am feeling pretty embarrased asking so many doubts.But,still I have few more :shy: .
  • #67
Why would the positions of the disks relative to the CM remain at constant radii from the CM after maximal elongation? The spring force doesn't suddenly switch off, it will continue to pull the disks back inwards. Perhaps I am misunderstanding what you are asking.
  • #68
During that maximum elongation, the spring is stretched. So it pulls the disks further inward. During that phase of motion the disks gain inward radial velocity, and after the spring regains its original length, the disks will move further inward and compress the spring. The motion is rotation and vibration at the same time. Two-atomic molecules do such motion and you can see nice rotational-vibrational spectrum of them in the infrared domain: transition between rotational levels superimposed to a vibrational transition. ( I saw many of them in my active life working with an IR spectrophotometer.)
ehild
Likes 1 person
  • #69
In any uniform circular motion, the force acts perpendicular to the instantaneous direction of motion, which is what is happening here (at the time when elongation is maximum). My question is - can we show that the spring force, which pulls the disks inward as you said, does not change the magnitude of the velocity, but only it's direction, like in circular motion? I'm not saying that the force switches off - I'm asking if the force is such that it only changes the direction of the velocity vector.
  • #70
My god ehild you and your pretty diagrams :) Is there a badge for best diagram provider?
  • #71
I think it depends on the parameters, k, Vo, m, and lo. It can happen that the spring force provides the centripetal force for rotation with constant angular speed, but it can go on both with rotation and vibration. We should examine it ...
ehild
  • #72
So ultimately will we have to prove what I wrote in post #65? In other words, is that a 'test' for any force acting always perpendicular to the velocity vector?
  • #73
The spring force will change both the magnitude and direction of the radial velocity. As for the angular speed of the rotation about the CM, this will be given in magnitude by ##\dot{\theta} = \frac{L}{mr^{2}(t)}##. The only time varying quantity is ##r(t)##.
  • #74
If instead of a spring,we had a massless ,inextensible string connecting the two masses,how would the situation have been different ?
First,an impulsive tension would act on masses,and afterwards,the system would have translated and rotated about the CM,just as we have in this problem.The tension after a while would have been constant .Right?
  • #75
ehild
If the spring is relaxed initially, as in the this problem, circular motion will never result. In circular motion the spring has to be uniformly extended everywhere, and the extension must be just right to provide const centripetal acceleration for the given constant speed.
Any kind of central force field admits circular motion, but initial conditions must be fine tuned.
  • #76
Well, do it in polar coordinates, substituting the two particles with a single one with reduced mass μ=m/2, and r as their distance.
The radial acceleration is
\ddot r-r{\dot {\theta}}^2=- \frac{k}{\mu}(r-Lo)
From conservation of angular momentum r^2 \dot {\theta}=A (A is a constant)
Note that conservation of angular momentum allows simultaneous change of both the radius and angular speed.
We arrive at a de for r: \ddot r-\frac{A^2}{r^3}=- \frac{k}{\mu}(r-Lo)
with initial condition r(0)=Lo and dr/dt(0)=0
ehild
  • #77
How do we prove this?
  • #78
The spring force acts along the radial direction in the CM frame so it will change the magnitude of the radial velocity and the change in direction happens periodically due to the spring wanting to restore itself back to the unstretched state. Also see post #76 above.
  • #79
The force will change the direction of the entire velocity vector. The radial velocity will change its direction without any force, provided azimuthal velocity is non-zero.
  • #80
As usual, multiplying that by ##\dot r## allows it to be integrated to arrive at ... conservation of energy, and quite a nasty DE it is :frown:.
  • #81
How does ehild's post #76 prove that the magnitude of velocity will necessarily change or in other words that circular motion is not possible with the initial conditions chosen?
  • #82
If motion is circular, then ## r \equiv l_0 ##, and ## \dot{r} \equiv 0 ##. Plug these into the equation, and you get $$ - \frac {A^2} {l_0^3} = 0 $$ The only solution is ## A = 0 ##, then ## \dot{\theta} \equiv 0 ##, which means there is no rotation at all.
  • #83
ehild
I also analyzed this problem using polar coordinates (this problem begs to be solved in cylindrical coordinates), and got the same result that you did. I then linearized the term 1/r3 by expanding in a Taylor series and then solved the resulting 2nd order linear ODE. But, in the end, I got a slightly different final answer than that indicated by the OP:
elongational strain = \frac{\frac{mv_0^2}{kl_0^2}}{1+1.5\frac{mv_0^2}{kl_0^2}}
Of course, if the elongational strain is small, the second term in the denominator can be neglected.
  • #84
Thanks voko! (And ehild, WBN and the others).
  • #85
The relative change of the length of spring u=L/L0-1 fulfils the differential equation
\ddot u-\frac{v_0^2/L_0^2}{(1+u)^3}=-\frac{2k}{m} u
If u<<1 he equation can be approximated by
\ddot u-\frac{v_0^2}{L_0^2}(1-3u)=-\frac{2k}{m} u
that is
\ddot u+(\frac{2k}{m}+3\frac{v_0^2}{L_0^2})u=\frac{v_0^2}{L_0^2}.
The initial conditions are: u(0)=0 and du/dt=0 at t=0, as initial velocity was perpendicular to the spring.
The solution is of the form u=B(1-cos(ωt)), where
\omega^2=\frac{2k}{m}+3\frac{v_0^2}{L_0^2}
and
B=\frac{v_0^2 /L_0^2}{2k/m+3v_0^2/L_0^2}.
The spring oscillates between the relaxed length Lo and its maximum elongated length. Circular motion is possible if the spring was initially stretched by the appropriate amount.
ehild
  • #86
This is exactly the result that I got, as expressed in post #83.
Chet
  • #87
Sorry, I wanted to mention your post but I forgot ...
ehild
  • #88
I seem to have lost track of why this thread has continued. I thought it had already been established that the book answer was correct. The above may be more accurate, but from the provided information that B << 1 we can deduce that 3v_0^2/L_0^2 &lt;&lt; 2k/m, allowing the 3v_0^2/L_0^2 term to be dropped.
Btw, I think all versions of the result can be reached more quickly using conservation of energy and of angular momentum. If x is the max elongation and v the speed of each mass at that time, and we use the suggested frame of reference:
Energy ##= mv_0^2/4 = mv^2+kx^2##
Ang mom ##= mv_0L = 2mv(L+x)##, whence ##v = v_0(1+x/L)^{-1}/2## (since the speed must be purely tangential at max elongation), etc.
  • #89
There was a question what happens after reaching maximum elongation. It is not forbidden to think about the problem further. DreamLord suggested (#65) that the disks will continue to move along a circle of constant radius around the CM. I have shown an approximate solution, which is a rotational-vibrational motion.
ehild
  • #90
His concern had been addressed earlier, using exact equations of motion.
