AStaunton
- 100
- 1
trying to show that the maximum of a certain function is \sqrt{\frac{2kT}{m}}.
The function in question is:
f(v)=4\pi(\frac{m}{2\pi kT})^{\frac{3}{2}}v^{2}e^{-\frac{mv^{2}}{2kT}}
so to do this find df/dv and set that = 0 and the value for v will be the v_max:
\frac{df}{dv}=2ve^{-\frac{mv^{2}}{2kT}}-\frac{2kT}{m}e^{-\frac{mv^{2}}{2kT}}=e^{-\frac{mv^{2}}{2kT}}(2v-\frac{2kT}{m})=0
now divide out the (2v-2kT/m) term leaves:
e^{-\frac{mv^{2}}{2kT}}=0
take natural log of both sides:
-\frac{mv^{2}}{2kT}=1\implies v=\sqrt{-\frac{2kT}{m}}
The answer I found was wrong by a minus sign, can anyone tell me where along the line I somehow created this extra minus? Also, I'm not sure if it is completely kosher to divide out the (2v-2kT/m) term as I did, so also please give clarification on this.
And final question; if the dividing out the (2v-2kT/m) is a correct method to solve this problem, should it also be possible to divide out the exponential term instead...that is when I'm at this point:
should I be able to divide out the exponential term and then also expect to find an identical value for v_max, ie. solve the following for v and this will be my v_max:
2v-\frac{2kT}{m}=0\implies v=\frac{m}{kT}
clearly this is not the value for v_max that was stated in the start of the problem...so clarity on this is much appreciated
