Finding the overall uncertainty
  • Thread starter Thread starter Ch3m_
    Uncertainty
To find the overall uncertainty of R, defined as R = (h² + l²) / 2h, one must apply the differential method, using the uncertainties in h and l. The uncertainties provided are ±0.57% for h, ±1.14% for h², and ±7% for l². It's crucial to differentiate between actual uncertainties and percentage uncertainties, as they are not the same; actual uncertainty is a fixed value while percentage uncertainty is relative to the measurement. The calculation of uncertainty in h² involves multiplying the percentage uncertainty of h by 2. Understanding these distinctions and applying the correct formulas will yield the overall uncertainty for R.
Ch3m_
How do I find the overall uncertainty of R when R = (h2+l2)/2h
uncertainty in h = ±0.57%
uncertainty in h2=±1.14%
uncertainty in l2=±7%
√1.142+72+0.572
Use the "differential"- R = (h2+l2)/2h dR= [(1- 2(h^2+ l^2))/h^2]dh+ (l/h)dl. Set dh and dl equal to the uncertainties in h and l respectively. You will need "current" values for h and l as well as for dh and dl. I do not understand you last values. Where you have "h = ±0.57%" do you mean the uncertainty in h (my "dh") rather than h itself? Also you have "h2=±1.14%" which is 2 times your h, not h squared.
<br /> <br /> Yeah those are the actual uncertainties in the values<br /> h = ±0.57% is the % uncertainty, where h is a measurement of length in m<br /> To get the uncertainty in h<sup>2</sup> you multiply the %uncertainty of h by 2 yeah?
To get the uncertainty in h2 you multiply the %uncertainty of h by 2 yeah?
You are confusing me by saying "actual uncertainty" at one point and "% uncertainty" at another- those are NOT the same thing. If h= 10, say, and the "actual uncertainty" (I would say "relative error") is 0.5 then the "percentage uncertainty" is (0.5)/(10)= 0.05= 5%. If f(x)= x2 then df= 2x(dx) The "actual uncertainty in f is 2 times the value of f time the "actual uncertainty" in x. The "percent uncertainty" in f is df/f. Dividing both sides of the previous equation by f, df/f= 2x(dx)/f= 2x(dx)/x2= 2(dx/x) so the percent uncertainty in x2 is 2 times the percent uncertainty in x.
There is an engineer's "rule of thumb" that "when quantities are added their errors add and when quantities multiply their relative errors add".
