Finding the Support and Ratio of Mass for a Horizontal Lead Brick on Cylinders
  • Thread starter Thread starter cd80187
    Equilibrium
The discussion focuses on calculating the mass supported by two cylinders under a horizontally placed lead brick, with specific relationships between the cylinders' areas and Young's moduli. Participants clarify that the deformation of both cylinders must be equal, leading to the use of static equilibrium equations to find the forces acting on each cylinder. The equations derived indicate that the force supported by cylinder A is significantly greater than that of cylinder B, specifically in a ratio of approximately 5.28:1. Additionally, there is a query about converting this ratio into a fraction of the total weight supported by each cylinder. The discussion also touches on determining the ratio of the distances from the brick's center of mass to each cylinder.
cd80187
In Fig. 12-49, a lead brick rests horizontally on cylinders A and B. The areas of the top faces of the cylinders are related by AA = 2.4 AB; the Young's moduli of the cylinders are related by EA = 2.2 EB. The cylinders had identical lengths before the brick was placed on them. What fraction of the brick's mass is supported (a) by cylinder A and (b) by cylinder B? The horizontal distances between the center of mass of the brick and the centerlines of the cylinders are dA for cylinder A and dB for cylinder B. (c) What is the ratio dA /dB?
So since I don't know how to post the picture, i'll just describe it. There is a silver block placed on top of cylinder A on the left and cylinder B on the right. A has a larger diameter than B. The com of mass is labeled in between cylinder A and B, but a little bit closer to B. Two lines are drawn, one connecting the center of cylinder A to the center of mass of the brick, labelled d subscript A. There is another line drawn from cylinder B to the bricks center of mass labelled d subscript B.
Now for this problem, I do not even know where to start. I think that I am supposed to use the equation F/A = E ( change in L/L). I have no clue how to use this equation though, but it is the only one that is relevant to the problem. So also, could you explain this equation, because I have no clue how to use. Thank you for the help
The key here is that the brick rests horizontally on the cylinders. Therefore, each cylinder must deform by the same amount. Find the deformation of each cylinder using the axial deflection formula, and set them equal. Then use the static equilibrium formulae for sum of torques and forces = 0.
I'm having trouble with this one too. I know that the change in length of one equals the change in length of the other which means y1(F1/A1)L=y2(F2/A2) where y=Young's mod, F equals the force of gravity, L equals the total length of the brick, and A equals the area. So using the given numbers you get EA(F1/AA)L=2.2EB(F2/2.4AB)L. I'm just clear how, from these equations, do you get the fraction of weight each is supporting?
I also know you need to use the dA and dB (distances from the center of mass) such that (dA+dB)F2 and F1+F2=mg. Any help would be appreciated! Thanks!
"y1(F1/A1)L=y2(F2/A2) where y=Young's mod, F equals the force of gravity, L equals the total length of the brick"
You're setting the change in length of the cylinders equal; why does the length of the brick matter?
"EA(F1/AA)L=2.2EB(F2/2.4AB)L"
Despite the mistake you made in your previous equation, this one is correct. The "L"'s cancel out, and you can calculate F1/F2. That's the ratio of the weight the first cylinder supports to the weight the second supports. Do you know how to convert a ratio into a fraction?
So you would get EA(F1/AA)=2.2EB(F2/2.4AB). When I solve for F1, I get (.2EB(F2/2.4AB)/EA)*AA and F2=((EA(F1/AA))/(2.2EB))*2.4AB. Not sure where to go from here. And I'm not sure how to convert a ration to a fraction. Thanks for helping btw.
I find these terms EA, EB, AA, AB very confusing the way they are written. Anyway, the deflections of both cylinders are equal. That implies
F_AL/A_AE_A = F_BL/A_BE_B
And since A_A = 2.4A_B and E_A = 2.2E_B, then
F_AL/((2.4A_B)(2.2E_B)) = F_BL/A_BE_B
The L,A_B and E_B cancel, and you are left with
F_A/((2.4)(2.2)) = F_B, or F_A = 5.28F_B.
Now continue...
Thx! That really helps! But how do you convert 1:5.28 to a fraction part of the whole? Haven't had to do this in a while. :P
Oh nvrmind I got it! Thanks anyway!
I haven't either, could someone give me a hand with this step?
I also have another step to this problem: The horizontal distances between the center of mass of the brick and the centerlines of the cylinders are dA for cylinder A and dB for cylinder B. What is the ratio dA/dB?
