Find Weight of 800 kg Turtle Raised 5.45 m
  • Thread starter Thread starter duckywucky
    Weight
To find the weight of the turtle, the work done against gravity while lifting it can be equated to the change in potential energy. The formula used is m*g*h, where m is the mass, g is the acceleration due to gravity, and h is the height lifted. Given that the work done is 4.60 x 10^4 J and the height is 5.45 m, the weight can be calculated by rearranging the equation to find g. The turtle's weight is determined to be approximately 8000 N. This calculation illustrates the relationship between work, weight, and height in physics.
duckywucky
The largest turtle ever caught in the US had a mass of over 800 kg. Supoose this turtle were raised 5.45 m onto the deck of the research ship. If it takes 4.60 x 10^4 J of work to lift the turtle this distance at a constant velocity, what is the turtle's weight?
Weight's measured in N.
so what formula would you use?
Δ(KE) = 1/2 mv^2?
Δ(KE) = 1/2 mv^2?
Assume the turtle is lifted at a very slow speed. The change in energy is all a change in potential energy which is
m*g*h = 4.60 x 10^4 J
