Finding Total Vector Displacement for a Multi-Directional Trip
To find the total vector displacement for the trip, the motorist's movements are broken down into components using a Cartesian coordinate system. The first leg south results in a displacement of (0, -3600) meters, followed by a westward displacement of (3000, -3600). The final northwest leg contributes approximately (4272.292, -2328) meters. The total displacement vector is obtained by adding these components together. Clarification on whether to find just the total displacement vector or its magnitude is also discussed.
chris_soft_engineer
The problem is:
A motorist drives south at 20.0 m/s for 3.00 min, then turns west and travels at 25.0 m/s for 2.00 min, and finally travels northwest at 30.0 m/s for 1.00 min. For this 6.00-min trip, find (a) the total vector displacement, (b) the average speed, and (c) the average velocity. Let the positive x-axis point east.
I need help figuring out the total vector displacement. I just want someone to explain how you find it and let me work it please.
thanks for the help
you can use a cartisen coordinate system to figure out the vectors
you first travel south for 3600 meters, this would be (0 , -3600)
then you travel west for 3000 meters, add this to the first you have (3000 , -3600)
hen you travel 1800 meters at an angle of 45 degrees so you have ( 4272.292 , -2328)
you can do the rest right
That wasn't my question. My question is how do i find the total displacement.
Do i just add all of that together?
yes that should do it
Thanks so much for the help. :smile: :smile:
Adding the components will give you the total displacement vector. Are you sure that is what you want?
Perhaps you were thinking about the magnitude of the vector as well? Do you know how to find this?
