Finding Velocity of Rolling Ball
To determine the speed at which a ball must be shot from point P to land at a distance d of 5.80 cm, the discussion emphasizes using kinematics and energy conservation principles. The vertical heights h1 and h2 are provided, with h1 at 4.80 cm and h2 at 1.60 cm, which are crucial for calculating the time it takes for the ball to fall from h2. The horizontal velocity of the ball on the plateau can be derived from the known distance d. Energy transfers between kinetic and potential forms during the ball's ascent and descent must be considered to find the initial velocity at point P. The conversation highlights the need to apply projectile motion equations to solve for the required launch velocity.
GingerBread27
In Figure 11-36, a small, solid, uniform ball is to be shot from point P so that it rolls smoothly along a horizontal path, up along a ramp, and onto a plateau. Then it leaves the plateau horizontally to land on a game board, at a horizontal distance d from the right edge of the plateau. The vertical heights are h1 = 4.80 cm and h2 = 1.60 cm. With what speed must the ball be shot at point P for it to land at d = 5.80 cm?
Can someone give me a push in the right direction?
This is a kinematics problem. How much time would it take an object to fall from h2? Now you know d, so can you find the horizontal velocity of the ball on the plateau? Now consider the energy transfers (kinetic-potential and vice versa) that occur during the ball's travel up the slope, and you should be able to find initial velocity at P.
Don't get it...sigh
use the projectile equations to figure out the velocity you would need when the ball leaves the edge so that you would get that range.
2nd consider the energy required to make it up the ramp and also have the velocity of part one
then ur done
I know it deals with energy conservation but I can't remember the equation to use for projectile motion.
AIM me at greenman100
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
