How do I find the volume of gas using the given mass of oxygen?
  • Thread starter Thread starter thevinciz
    Gas Volume
To find the volume of gas using the mass of oxygen, the discussion emphasizes converting the mass of oxygen to moles and calculating the mole ratio of oxygen to nitrogen. The Ideal Gas Law is suggested as a method to relate these moles to volume. Participants clarify that the mole fraction of oxygen can be derived from the total moles of the gas mixture. Ultimately, the correct calculations lead to determining the mole fraction of oxygen, confirming the approach to solving the problem. The conversation concludes with the participant expressing satisfaction in reaching the correct answer.
thevinciz
I have tried to change mass of oxygen into mol and I got ratio of oxygen and nitrogen. And I don't really know what to do.
In common terminology, the term volume fraction is used synonymously with mole fraction.
Likes phoenix95
phoenix95 said:
Well done.
Now try using Ideal gas law. Use the mole ratio you obtained.
Could you explain more?
Do you mean mol of oxygen / mol of nitrogen is equal to volume of oxygen / volume of nitrogen? But I still don't know how to solve.
Let's see the details of what you did.
I got molO2/molN2 = 2.8/12.8 and from your comment I understand that volumeO2/volumeN2 = 2.8/12.8
This is incorrect. If you take as a basis 1 kg of gas mixture, what is the mass of oxygen in the mixture? What is the mass of nitrogen in the mixture? What are the number of moles of oxygen in the mixture? What are the number of moles of nitrogen in the mixture? What is the mole fraction oxygen? What is the mole fraction nitrogen?
In 1kg ,mass of O2 = 0.2 kg
mass of N2 = 0.8 kg
mole of O2 = 12.5
mole of N2 = 28.6
So total mole is 41.1 : mole fraction O2 = 12.5/41.1
mole fraction N2 = 28.6/41.1
mass of N2 = 0.8 kg
mole of O2 = 12.5
Moles O2 = 6.25
Chestermiller said:
Moles O2 = 6.25
I see
Chestermiller said:
Moles O2 = 6.25
Thanks I got the answer now, is it 6.25/6.25+28.6 right?
Likes Chestermiller
