Finding volume using integrals
  • Thread starter Thread starter donjt81
    Integrals Volume
donjt81
So here is the question
find the volume of the solid generated by revolving the region bounded by the curve y = sqrt(16 - x^2) and the line y = 0 about the x axis.
this is how I solved it
\int_{0}^{4} \Pi (16 - y^{2}) \; dy
\Pi \int_{0}^{4} (16 - y^{2}) \; dy
pi(16*y - y^3/3) from 0 to 4
pi(16*4 - 64/3 - 0)
so the answer I got is (128 pi)/3
is this correct.
Unless I'm missing something, you should multiply your whole integral with 2, since your function is defined from -4 to 4 and symmetric.
Well, why haven't you used -4 as your lower limit?
Note that this would double the volume of your object.
Another check is to recognize that y= \sqrt{16- x^2} is the upper half of a circle and so the figure formed is a sphere of radius 4. Its volume is (4/3)\pi (4)^3, twice your answer.
thanks guys i completely missed that. you are right it should be -4 to 4... other than that does everything else look ok.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
