Finding z component of center of mass of a complex shape
The problem involves determining the z-coordinate of the center of mass for a rigidly connected unit consisting of a circular disk, a round shaft, and a square plate, with specified masses for each component.
  • Exploratory, Assumption checking
  • Participants discuss the calculations for the z-coordinates of the components and question the assumptions made regarding the placement of the square plate at z = 0. There is a request for a diagram to clarify the orientations and dimensions of the objects involved.
Some participants have provided clarifications and suggestions regarding the need for a diagram and the assumptions about the thickness of the square plate. There is an ongoing exploration of how the center of mass is affected by the positioning of the components.
Participants are considering the implications of the plate's thickness on its center of mass and how changes in position might affect the calculated z-coordinate.
Ella Tankersley
The rigidly connected unit consists of a 2.5-kg circular disk, a 2.8-kg round shaft, and a 4.2-kg square plate. Determine the z-coordinate of the mass center of the unit.
∑zm/∑m
Circular disk:
mass = 2.5 kg
z = 0
zm = 0
Round Shaft:
mass = 2.8 kg
z = 180/2 = 90
zm = 90(2.8) = 252
Square plate:
mass = 4.2 kg
z = 0
zm = 0
Total mass = 2.5+2.8+4.2 = 9.5 kg
Total mz = 252
∑zm/∑m = 252/9.5 = 26.5 mm
I think we'll want to see a diagram or better description of the orientations, placement, and dimensions of the objects. We shouldn't have to fish about in your solution equations to find the statement of the problem.
I added a diagram, can you see it?
Ah! Much better! Thanks.
Square plate:
mass = 4.2 kg
z = 0
zm = 0
I don't understand this calculation. Why is the plate at z = 0?
I was assuming that the plate is very thin so there is no thickness in the z direction
What has the plate's thickness have to do with its center of mass position with respect to the xy plane?
Edit: removed spurious thought that I thought I'd removed before posting. Sorry about that.
OK, so assume the mass of the plate is all at the same z value. And that's the z coordinate of the center of mass. What is that z value?
Let me put it a different way. You figure the center of mass of the circular disk is at z = 0. Fine. Now suppose I pick the disk up, raise it 20 meters. Is its center of mass still at z = 0?
  • · Replies 23 ·
