What is the relationship between FS and HFS in the 3s3p Configuration?
Henk
I'm having some problems with the Fine and Hyperfine splitting (FS and HFS). For example the 3s3p Configuration, I understand the FS:
*****************************_______Mj=1
************1P________J=1*****_______ Mj=0
*****************************_______ Mj=-1
************3P______ Is split into J=0,1,2 and they are split into the Mj levels
3s3p_____
But where then is the HFS. I understand that I and J couple to F and that gives MF-levels but I don't know where to put in the picture above.
edit: the picture isn't very clear, sorry had to add some stars.
3s3p_____
What is the degeneracy of the Mj levels in the absense of the HFS ?
Perhaps, I should ask this first : Do you know where to put the hyperfine levels for the 1s orbital ?
For the 1s Orbital: L=0, S=1/2 thus J=1/2. That means the level has FS for J = 1/2 and J = -1/2. I don't know I so I can't give the F values however I suppose that the J-levels are splitted into the F-levels. And that if there is an external magnetic field (weak) the F-levels are splitted into 2F+1 Mf levels. Is this correct?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
