Finite element simulation of a solenoid
The discussion focuses on performing a finite element simulation of a coil in a time-varying magnetic field to analyze induced current and its effects on the surroundings. The user seeks advice on modeling a coil with thousands of turns, considering the use of a cylinder with specific material parameters. There is a query about how to define these parameters effectively, particularly in the absence of certain functionalities in the available software. The user mentions previous experience with MAXWELL, noting the method of applying current excitation based on the number of turns. The conversation aims to gather insights on practical modeling techniques and software capabilities for simulating solenoids.
daudaudaudau
Hi all.
I would like to do a finite element simulation of a coil in a time-varying magnetic field, to see how much current is induced in the coil, and also to see how the coil itself affects its surroundings. Now my question is, how do I model a coil with several thousand turns in a practical finite element simulation? I was thinking that maybe I could just draw a cylinder and assign some (possibly anisotropic) material parameters, but then what should these be? I hope someone has an idea!
Do you know how to use the program MAXWELL?
I am aware that Maxwell has some way of defining solid cylinders as coils, but this functionality does not exist in the software I have access to. Do you know how Maxwell implements this feature?
The last time I simulated a solenoid on MAXWELL, my assigned current excitation was the product of the applied current and the number of turns. The solenoid was a hollow cylinder with the excitation applied in the direction of the flowing current.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
