Finite Element Symmetry Problem
A finite element analysis on a symmetrical cylinder is yielding identical stress results for both quarter and full models, but deflections differ significantly. The issue may stem from incorrect deflection constraints applied to the quartered section, as the edges need to remain perpendicular to the cut planes. Ensuring proper boundary conditions and constraints is crucial for accurate deflection results. Further investigation into the modeling setup and constraints is recommended. Accurate modeling is essential for reliable finite element analysis outcomes.
scootypuffsnr
Hi,
I am running a finite element on a cylinder with that converges at the bottom for a opening, which is symmetrical in both directions so i modeled one quarter but the problem is my stresses are the same with when i compare with a full model that i also done but the deflections are different
any help will be greatly appreciated, thank you
scootypuffsnr said:
Hi,
Maybe the deflection constraints for the quartered section are incorrect? The edges must remain perpendicular to the cut planes.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
