How Strong Does a Fishing Line Need to Be to Stop a Drifting Salmon?
  • Thread starter Thread starter Kawasaki268F
    Line Strenght
To determine the minimum strength of a fishing line needed to stop a drifting salmon weighing 78 N over a distance of 13 cm, constant acceleration equations must be applied. The initial horizontal velocity of the salmon is 3.1 m/s, and the problem involves calculating the necessary deceleration to bring the fish to a stop. Using the equation Vf^2 = V0^2 + 2a(x - x0) along with F = ma, the required force can be derived. The tension in the line must match or exceed this force to effectively stop the salmon. Accurate calculations are essential to ensure the fishing line can withstand the required strength.
Kawasaki268F
The tension at which a fishing line snaps is commonly called the line's “strength.” What minimum strength is needed for a line that is to stop a salmon of weight 78 N in 13 cm if the fish is initially drifting horizontally at 3.1 m/s? Assume a constant deceleration.
I need to use constant acceleration equations...so: v=V0+at, x-x0=v0t+(1/2)at^2...there are 3 other equations for constant acceleration but I don't think i have learned them yet.
I am pretty stuck on this one as I have no idea which equation to use and what to do after that to find the solution
I got it with the help of a friend using Vf^2=V0^2+2a(x-x0) and F=ma
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
