Fishing rod mechanics and curvature calculations
The discussion focuses on creating a stainless steel piece with varying thickness to achieve a specific cam profile similar to a fishing rod. It highlights that the bending profile changes based on whether the thickness transition is uniform or not. Participants suggest using finite element analysis and mathematical modeling to derive the necessary thickness variation for the desired bending profile. They note that the deflection of a beam can be described by a fourth-order ordinary differential equation, which can be solved to find the moment of inertia. Ultimately, using software for numerical analysis is recommended as a practical approach to achieve the desired results.
cardboard
i am trying to make a piece of stainless steel of varying thickness bend in such a way that it creates a cam profile in much the same way a fishing rod works.
for example if the thick end has a 5mm by 10mm cross section and the thin end is 1mm by 10mm crosssection and the change in thickness is uniform down the length then a certain profile will be induced when the beam is bent if the thick end is fixed.
if the transition from 5mm to 1 mm is not uniform i.e. the first 100mm of the beam is 5mm and the last 100mm is 1mm then a different profile would be induced when bent about the thick end.
i need a method of calculating what rate of change in thickness i need to give a certain profile?
can anyone help?
thanks
Finite Element Analysis!
Hmm deriving the variation of cross section from the deformed geometry is sort of reverse of what the usual trend is. But it can surely be done with a sound understanding of the subject.
are you asking for more detail or saying you don't have the knowledge in this area?!
From what I understand, the deflection in a beam is a 4th order ordinary differential equation. I would assume that if you assume a function for the displacement, then you can integrate (or maybe derivate) to obtain a function for the moment of inertia.
I am telling you the easiest way out. Just crunch in numbers in a software & wollaa.(hit & trial method)
Exactly. I just thought that would be a bit too much maths.
there you go...
http://www.efunda.com/formulae/solid_mechanics/beams/theory.cfm
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
