Flow Development: Is psi = 4y - (y^3)/3 Fully Developed?
  • Thread starter Thread starter banerjeerupak
    Flow
The discussion focuses on determining whether the given stream function, psi = 4y - (y^3)/3, indicates a fully developed flow of water at 20°C. A flow is considered fully developed when there is no change in the velocity component in the flow direction, specifically when du/dx = 0. Participants seek guidance on how to analyze the stream function to assess flow development. The conclusion emphasizes that recognizing the condition of the velocity component is key to understanding flow development. Understanding these principles is essential for solving similar fluid dynamics problems.
banerjeerupak
The following stream function holds for a certain flow of water at 20 C.
psi = 4y - (y^3)/3.
Is this flow fully developed?
psi = 4y - (y^3)/3.
How am i suppose to tell if a flow is fully developed or not from the stream function? Direct me to what should i study to find the answer.
I found the solution ..so here it is... for a flow to be fully developed, it should have no change in the u component. i.e. du/dx = 0
