Fluid Dynamics: quickest way to pour water out of a bottle
The discussion focuses on the quickest methods to pour water from a bottle, particularly for a 4000-word essay. One effective technique mentioned is using a bendy straw, which helps equalize pressure and allows water to flow faster. Another method involves swirling the bottle to create a vortex, facilitating air entry and enhancing the pouring speed. The effectiveness of these methods has been observed in demonstrations, particularly with bottles like Perrier. Overall, understanding fluid dynamics and pressure relationships is crucial for optimizing water flow from a bottle.
blondnc
I am doing a 4000 word essay on the quickest way to pour water out of a bottle and i need some help with the theory and formulas etc. I've tried looking but this experiment isn't well documented so any help would be great!
Well, from experience, the strawpedo works pretty well. If you stick a bendy straw in the bottle, it will come out a lot faster.
I think this is because it equalises pressure in the bottle. Otherwise, there is a lower pressure which causes the water to slow down.
Hopefully someone can give you a better answer.
The "how" answer is to swirl the bottle so that a vortex forms a funnel allowing air up to the bottom of the bottle. When I have seen it demonstrated, in the lecture that you may have missed, it was done with two perrier bottles, I am not sure that was to maximise the effectiveness of the demonstration but it was very noticible that the "swirled" bottle emptied quickest.
im aware at botht but i wanted to focus on it without using extra apparatus etc to look at angles and relationships between neck sizes
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
