Water Speed From a 1.5m Height Container
A container filled with water to a height of 1.5m has a hole at the bottom that allows water to squirt out horizontally at a height of 2m. The discussion focuses on calculating the speed of the water as it exits the hole. Participants emphasize the importance of posting relevant equations and demonstrating attempts at solving the problem in accordance with forum guidelines. The conversation highlights the need for a clear understanding of fluid dynamics principles to determine the water's exit velocity. Proper engagement with the forum's rules is encouraged for effective problem-solving.
walkofdeath
A container is filled with water to a height of 1.5m. A hole at the bottom let's water squirt out horizontally at a height of 2m above the ground. How fast is the water moving that shoots out the hole?
Hi walkofdeath,
Welcome to the forum, but... you need to post the equations you suspect are relevant and show your attempt at solution. Please see the Forum guidelines.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
