How Do You Calculate Fluid Force on a Rotated Square Tank?
To calculate the fluid force on a rotated square tank filled with oil, one must set up a definite integral based on the tank's dimensions and the oil's weight-density. The tank has a height and width of 12 feet, with oil at a depth of 4 feet. The fluid force can be expressed using the formula f = pA, where pressure (p) and area (A) are functions of depth. The area function must account for the tank's 45-degree rotation, affecting how pressure varies with depth. Properly defining these functions is crucial for accurately calculating the fluid force.
tnutty
A metal oil tank has cross-section that is a square rotated 45 degrees as shown in the figure above. Its height is 12 ft and width is 12 feet. The oil in the tank has a weight-density of 57 lb/ft3.
Write a definite integral that expresses the fluid force on the end of the tank when the oil is 4 feet deep?
Here is a link to the photo :
http://img17.imageshack.us/img17/2294/76984288.jpg
hopefully you can make it out.
I am not sure how to set up the definite integral.
Well, I think you can figure out out that
f = pA
Right?
Area is a function that you have. Pressure is a function as well. What are these functions?
