Fluid flow and elevation vs pressure
The discussion centers on the relationship between elevation change and pressure loss in pipes, specifically addressing hydrostatic pressure and head loss due to flow restrictions. A user seeks supporting research for their experimental data showing a negative gradient graph related to pressure changes in a hydraulic system involving both horizontal and vertical pipes. Responses clarify that the scenario likely involves hydrostatic pressure and provide relevant equations and resources for further understanding. The conversation emphasizes the fundamental nature of the principles involved, suggesting that the user may not need extensive additional research. Overall, the thread highlights the importance of understanding basic hydraulic concepts in analyzing fluid flow and pressure dynamics.
lifeisstrange444
TL;DR Summary
Request
Hey guys! does anyone have a graph of the relationship between elevation change and pressure loss in pipes? I currently have experimental data of a negative gradient graph. know it's theoretically correct however, I just need supporting research for this - have tried finding everywhere but can't find it
Welcome to PF.
There are many interpretations of your question. I wonder what you mean.
Are you referring to hydrostatic pressure reduction, or a head loss due to flow restriction?
Please describe the hydraulic system, and attach the "negative gradient graph" to your next post.
Likes DeBangis21 and russ_watters
Hi, a change in pipe elevation. My setup is currently; horizontal pipe into vertical pipe and from the vertical pipe into another horizontal pipe. The last pipe is in partial flow and so im assuming the pressure is atmospheric pressure. I am then backtracking to find P1 (original pressure) - and finding the change in pressure due to the elevation. Attached is my graph - would really appreciate your help, thank you
That appears to be hydrostatic pressure. The equation is here.
https://en.wikipedia.org/wiki/Vertical_pressure_variation
Your coefficient 9961.4 should be close to g * density.
For g = 9.8 m/s2 the liquid is water, with a density of 1016 kg/m3.
What "supporting research" do you require for something so fundamental ?
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
