Flux through a cylinder
In summary, the electric field for a point charge on the axis of a cylinder is given by \vec{E} = q \vec{r} / \| \vec{r} \| ^3. To calculate the flux of this field outward through the cylinder x^2 + y^2 = R^2, for 0 \leq z \leq h, we consider the three surfaces of the cylinder (side, top, and bottom) and calculate their respective integrals. The flux out of the volume enclosing the charge is 4\pi*q, but since the charge lies in the plane of the bottom lid, the flux is reduced to half of that. Using cylindrical coordinates, the z=0 integral is zero
villani
A point charge is on the axis of a cylinder at its center. The electric field is given by:
[tex] \vec{E} = q \vec{r} / \| \vec{r} \| ^3 [/tex]
Compute the flux of [tex] \vec{E} [/tex] outward through the cylinder: [tex] x^2 + y^2 = R^2 [/tex], for [tex] 0 \leq z \leq h [/tex]
[tex]
\int \vec{E}d\vec{A} = \int \vec{E}\vec{n}dA
[/tex]
We consider the three surfaces: side of the cylinder, top and bottom of the cylinder.
The unit normal vector to the side is: [tex] \frac{x \vec{i} + y \vec{j}}{\sqrt{x^2 + y^2}} [/tex]
The unit vector to the top is k
The unit vector to the bottom is -k
If we consider the three surfaces and three integrals. We sum them to get the result.
Should the result be (Gauss Law):
[tex]
4q\pi
[/tex] ? How do we prove it?
Are the integrals for the top and bottom equals to zero?
How do we calculate the integral for the side of the cylinder?
[tex] \int \vec{E}\vec{n}dA = \int q \vec{r} / \| \vec{r} \| ^3 \vec{n}dA [/tex]
The field described is that of a point charge (q) at the origin, so the flux out of a volume that encloses the charge is [tex]4\pi*q[/tex]. Now, for the given cylinder the charge lies in the plane of the bottom lid [tex](z=0)[/tex], reducing the flow to half of that you'd get if the charge was enclosed in the volume. To convince yourself of this you can crank through the integrals using cylindrical coordinates [tex](R,\phi,z)[/tex]. The [tex]z=0[/tex] integral is zero, and the other two add up to [tex]2\pi*q[/tex].
1. What is flux through a cylinder?
Flux through a cylinder is a measure of the flow of a vector field through the surface of a cylinder. It is a way to quantify the amount of fluid, energy, or other substance passing through a given area on the surface of the cylinder.
2. How is flux through a cylinder calculated?
The flux through a cylinder is calculated by taking the dot product of the vector field and the unit normal vector of the cylinder's surface, and then multiplying it by the surface area of the cylinder.
3. What factors affect the flux through a cylinder?
The flux through a cylinder can be affected by the strength and direction of the vector field, the orientation of the cylinder, and the surface area of the cylinder.
4. What is the unit of measurement for flux through a cylinder?
The unit of measurement for flux through a cylinder depends on the unit of measurement for the vector field and the surface area of the cylinder. For example, if the vector field is measured in Newtons and the surface area is measured in square meters, the flux would be measured in Newton-meters.
5. What are some real-world applications of calculating flux through a cylinder?
Some real-world applications of calculating flux through a cylinder include studying fluid flow through pipes, calculating the electric field strength around a charged cylinder, and analyzing the flow of heat through a cylindrical object.
