Fokker Planck Solution Biased Random Walk
beth92
This is part b) of an assignment question. In part a) we were asked to derive the Fokker Planck relation for the biased random walk. The answer is:
dP/dt = -vdP/dx + D d2P/dx2
Where the first term is the drift term due to the biased motion and the second term is the diffusion term.
Then in part b) we were asked to solve this differential equation for P(x,t). I already have the written out solution to this question however I don't understand one of the steps the lecturer has taken.
First of all we define a new frame of reference y=x-vt in an attempt to get rid of the drift term (as we will then simply have the non-biased fokker-planck relation which we can solve). We then set out to rewrite the partial derivatives from the above equation in terms of the new variable y. Here the lecturer's solution emphasises that when deriving with respect to time, y is not a constant (y=y(t)) and x is considered constant. He writes the following:
dP(y,t)/dt |x=const=dP(y,t)/dt|y=x-vt
=dP(y,t)/dt + dy/dt * dP(y,t)/dy
I'm not sure why he has taken that last step - where have the two terms come from? It seems to me like he is adding the derivative twice (as the second term in the last line is just the dP/dt term again expanded using the chain rule).
If anyone can explain why he's done it this way then I will understand the rest of the question okay.
Thanks!
It's just the chain rule:
\frac{d}{dt} f(y(t), z(t)) = \frac{\partial f}{\partial y} \frac{dy}{dt}+\frac{\partial f}{\partial z} \frac{dz}{dt}
Where your function has the form P = P(y(t), t) <-- has two t dependent terms
To make this clearer let y(t) just as is and put z(t)=t, So that your P(y(t), z(t)),
So by the chain rule
\frac{d}{dt} P(y(t), z(t)) = \frac{\partial P}{\partial y} \frac{dy}{dt}+\frac{\partial P}{\partial z} \frac{dz}{dt}
but remember z was just t, so dz/dt=1 and you get
\frac{d}{dt} P(y(t), z(t)) = \frac{\partial P}{\partial y} \frac{dy}{dt}+\frac{\partial P}{\partial t}
The Last piece is just a bit of notational detritus since P is actually a function of x
too you write the derivative on the left as partials
\frac{\partial }{\partial t} P(y(x,t), t) = \frac{\partial P}{\partial y} \frac{dy}{dt}+\frac{\partial P}{\partial t}
but you have to remember that \frac{\partial }{\partial t} has different meanings on each side
of the equation. on the left it is holding x constant while on the right it is holding y constant.
That makes perfect sense now, thanks a lot!
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
