Force Applied at an Angle to an Object on Frictionless Surface
The problem involves a block sliding on a frictionless surface with a force of 20 N applied at a 30° angle. The relevant equation is F=ma, where the force components must be considered. The user initially calculated the acceleration as 3.46 m/s² by only accounting for the horizontal component of the force. However, they overlooked the total force applied, leading to the correct acceleration being 7.5 m/s². The discussion highlights the importance of considering all forces when solving physics problems.
jpsmith394
The horizontal surface on which the block slides is frictionless. If F = 20 N and M = 5.0 kg, what is the magnitude of the resulting acceleration of the block? The force is applied 30° to the horizontal.
F=ma
I began by ignoring the weight and normal force in the vertical axis (y-axis) because the surface is frictionless. Then my next step is to separate the force into compenets with F_{x}=Fcos\theta
Therefore:
ƩF_{x}=Fcos\theta = ma_{x}
So:
a_{x}=\frac{Fcos\theta}{m}
And using the given numbers I got a solution of 3.46\frac{m}{s^2}
But the online system I am using shows the correct answer as 7.5\frac{m}{s^2}
hi jpsmith394! welcome to pf! :smile:
erm :redface: … you forgot the other F, in front! :wink:
Oh gosh I see now, I was just stuck thinking it was just a single force
Thanks,
James
